Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Questions View all
Headphone jack board connector pinout
I ripped the connector off of the ribbon cable for the headphone jack and I cant find any replacement parts. So, I am going to attempt to bypass the ribbon cable connector by soldering to the test pads on the ribbon cable. I've found that pads 6,7,8 go to sleeve, ring, and tip respectively. I would like to solder wires from these pads to the correct pins on the connector socket on the logic board but cant find any information on which pins are the right ones. Nor is the ribbon cable made in a way that I can trace the pads to the (now gone) connector.
Please help :)
Add a comment
1 Answer
I don’t know the actual pinout for the audio flex connector but I have a spare one (I could give it to you for free but I’m in Venezuela). If you want I can send you a PM or an email with images of the connector for you to check the pinout.
1 Comment:
Hey there that would be awesome! Can you email me at murmuzy@gmail.com?
Thank you
by
Add a comment
Add your answer
Nathan Thomas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 95
