The Plantronics BackBeat Go 410 is a noise canceling wireless earphones.
5 Questions View all
BB Go 410 “Power on" then unusable. How to fix this?
I have a unit of BB Go 410 that when turned on says “Power on" then stop and unusable. If normal it should says “Power on, battery high/medium/low”, then usable (directly to music or anything else I'm listening to). I can still charge it and the lamp indicator can still show whether it's charging or full.
In my case usually if I leave it for hours it went back to normal and I can use it, but it keeps disconnected from my phone until eventually it went back to the previous state (“power on" then unusable). While in my wife case (a different but same type unit) every time we try to turn it on its always “Power on” then unusable.
Any suggestion to fix this issue?
Score 1
Add a comment
Most Helpful Answer
1 Side Sound Not Working
Score 2
Add a comment
Hey,
4 years after your message, the same thing is happening to me. Any chance you found a solution but didn't post it here... ?
Thanks so much.
1 Comment:
I tried resetting to it to factory settings using the Android App, but it didn't work...
by
Add a comment
same happened. fixed it bypressing all buttons in many combinations for a long time
Add a comment
Add your answer
Zulfikar will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 37
All Time: 460
