Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Mac mini 2011 won't boot and vertical lines.
My macmini is suddenly got verical lines on screen. And then problem with start up. I cannot go to recovery Mode. I can go to safe mode. But i don’t know what to write there to be able to go to recovery mode again. When i go to recovery i see the globe but after the indicated time is finished the screen turns to white. Can anybody please help me what to do? Thanks in advance.
6 Comments
Can you tell us which model you have Apple produced two versions:
Macmini5,1 - HD Graphics 3000
Macmini5,2 - Radeon HD 6630M GPU
by
Hello Dan, thank you. Can you please tell me where can I see that.? Because I cannot go to the computer. It can not boot correctly. I have the box. The model is A1347. Is it this one? Or can I see it from the safe mode? Please help me on this. I am not very familiar with apple.
by
Locate your systems S/N from the system and plug it in to here EveryMac - Lookup
If you can get into Safe Mode then look at the About This Mac and then click on the System Report button click on the Graphics/Display section you should see one or two Video Cards listed.
by
I have the box. On the box i see that the s/n begins with CO
Macmini is 2.5, BEL/IEA. Can these information be needed to see the graphic card model. I will also try to single user mode (control s) to give you more details. I also did a hardware test that said no hardware issues found. Is that a good sign or not. Idk. But still vertical lines appearing and no recovery mode able. I appreciate your help.
by
Command s and i see just bunch of lines (like dos in windows) and then i have to write syntax language. My question is if i cannot solve the problem with syntex, which syntax command should i write to have at least the recovery mode back? Is that possible? Because i have no access to recovery or whatever but this. Thanks in advance
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Sadly your logic board has failed, you’ll need a new one Mac Mini Logic Board, 2.3 GHz i5 - Intel 3000 I would recommend getting this version of board as it will last a lot longer than the Mac Mini Logic Board, 2.5 GHz i5 - AMD Radeon 6630M version.
Here’s the guide you’ll need to follow Mac mini Mid 2011 Logic Board Replacement
Score 1
2 Comments:
Ok. That means no remedy but just buy another one or repair. As repairing or replacing costs a fortune i think that the other option would be smarter. Thank you so much for your support.
by
Thank you for your support.
by
Add a comment
Add your answer
Macminime will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 734
