Is there a way to check if my engine is getting fuel?
I can hear the fuel pump running but I’m not sure if I’m getting fuel to my motor. How do I check
It might have a fuel pressure test port in the line. If it doesn't you will have to unhook the line and put a fuel gauge in the line. Shops carry those sets but they run in the hundreds of dollars. If it has a test port you should be able to rent one from autozone, o'Reilly's, etc. You should also verify that you have spark.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 291
