Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
874 Questions View all
iPhone 8 bootloop when plugged in
I replaced a broken screen on an iPhone 8, after doing so it was stuck on a bootloop.
Nothing was changed except of the screen but I did remove some gunk from the charging port. When unplugged it showed a low battery symbol but when plugged in it was on an infinite bootloop.
I replaced the dock connector but with the same result: low battery symbol with lightning connector, when plugged in it briefly shows just the low battery symbol and after a while it goes on bootloop.
I think it just doesn’t have enough power to boot and maybe the battery is broken (seems strange though because before the screen was broken it worked fine).
someone told me it might be a motherboard problem because it doesn’t show up on iTunes either?
Thanks!
Add a comment
Most Helpful Answer
If it’s in a bootloop get it in recovery mode and try updating on 3UTools / iTunes.
Score 1
6 Comments:
I can't find the device on my computer (iMac mac os high sierra).
by
Once I get home I'll post instructions on how to put it in recovery mode it's pretty tricky on the iPhone 8.
Holding the side button while plugged in should be enough to kick it in recovery mode.
by
I can get it in recovery mode, it just doesn't show up on iTunes.
by
It can't charge nor make connection with a computer...
by
Can I ask if you fixed the issue? and what the problem was?
by
Show 1 more comment
Add a comment
Try disconnecting the earpiece (earspeaker) cable and try again.
Add a comment
Add your answer
Rembert will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 323
