The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
709 Questions View all
Accidentally popped off battery connector
I am a first-time repairer, I was replacing the Joy-con on my Switch using the tools I’d received in the Joy-con repair kit, and i accidentally popped off the battery connector. I am trying not to panic here, but I have no soldering tools. I presume superglue would be too risky a solution?
Score 1
2 Comments
Looks like part number is 0781710002
2 pin socket--same as the connection for Steamdeck haptic/touchpad which is what I needed it for. Confirmed by dissambling my Joycon and fitting the broken off socket from the Steamdeck onto the Switch battery.
by
Looks like it is a 0781710002 socket/2 pin connector. Same as the Steamdeck touchpad/haptic feedback connection--which is what I needed it for. Confirmed it fits by disassembling my Joycon and snapping the battery into the socket that broke off my Steamdeck.
by
Add a comment
1 Answer
Chosen Solution
no you should solder the connector in place cause the pins contact to the logic board will be bad. Any electronic repair shop can do it for cheap.
Score 2
1 Comment:
Thank you, I was really struggling with this, but do you know where i can order a replacement battery connector?
by
Add a comment
Add your answer
Becky Hopkins will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 54
All Time: 3,053
