The IBM ThinkPad 600E was released in 1998 as part of a series of laptops produced by IBM.
5 Questions View all
I can not get the fan/heat sink assembly out of this laptop.
The fan assembly feels loose however it wont come out. Its like the fan is swollen and stuck to the underlying assembly some how? Am i missing something ? I believe all the screws have been removed..
Add a comment
1 Answer
Most Helpful Answer
Hi @rabond ,
Here’s the hardware maintenance manual for the laptop.
Go to p.83-84 to view the necessary pre-requisite steps and then the procedure to remove the CPU card and the fan.
Hopefully this may help you to remove the fan
If the fan requires replacing, on p.109 Item #27 you will find the part number for the fan. Search online using the part number only will give results for suppliers of the part.
Score 2
Add a comment
Add your answer
Randy Bond will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 66
