20 pin data cable to a 30 pin? Possible?
I just sold my A1134 that had display issues. I have the old LCD screen that should still work from that lappy. Now i got a working A1055 with a busted screen, I thought I could just swap the screen out with the A1134 screen but no. The problem now is the data cable size and I'm not talking narrow or wide. The lappy with the busted screen's data cable is a 20pin. The screen I want to replace it with is a 30 pin wide.
Now for the question......on the A1055 logic board, can i buy the 30 pin wide data cable and have it connect to the logic board correctly? The trick here that really confuses me is that according to iFixit the A1055 model should already have the 30 pin. But I counted the pins and there is only 20 pins on the connector. From what I've seen the A1055 mod is for lappys with 933mhz-1.3ghz or something like that. So maybe the higher ghz have the 30 pin but my mod is a 933ghz and I can't find any detailed specs on the logic board display data connector to even compare the connectors.
thankx in advance for advice.
Score -1
Add a comment
1 Answer
Chosen Solution
Unfortunately no this will not work. Even with the same LVDS cables 99% chance the pin outs would be different on the connectors. If that didn't stop it from happening the frequency and voltage changes put out by the different GPU circuitry would. I am sorry you are best off selling your good LCD on eBay to help purchase the LCD you need.
Score 3
1 Comment:
You know now that I am pokeing around with the old lappy, granted I am happy to just have a mac lappy back, I am now finding the limitaions of it. The OS is so old, 10.3.9, that I cannot even get an upgraded web browser enough to watch netflix. I think I am just going to have to put the entire mac back on the market. :( very sad.
Thank you so very much for your help and insight.
by
Add a comment
Add your answer
Blox will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,337
