TI-84 Plus calculator support.
39 Questions View all
Why is a row of buttons on my TI 84 plus not working?
I’ve got a TI 84 Plus in good condition; the only problem is that not all of the buttons work. Specifically the buttons that aren’t working are the “log”, “7”, ”8”, “9”, “x (multiply)”, and the Up button on the keypad. The first 5 of these buttons are in a row straight across the keypad. I’ve tried cleaning the key mat and the big green motherboard, still nothing. There was some yellow gunk on the board when I cleaned, there might have been a battery leak at some point maybe? Any help would be very much appreciated!
Add a comment
1 Answer
If a whole row is dead then it’s likely the issue is a broken trace on the PCB. If you have a multimeter then you can probably pinpoint the place(s) where it’s broken and repair it if you know how to solder. There are many tutorials out there for fixing a broken trace, here is one I found. Let me know if you have any other questions!
Add a comment
Add your answer
Micah Yoder will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 736
