Replacement screen not sticking to device
I have replaced the screen on an iPad as the original was cracked. The new screen does not stay fully attached to the device, does the adhesive need to be heated for it to attach?
Which areas are pushing up? If its the bottom left you’ll need to use B7000 liquid glue to hold that corner down and use scotch tape to keep pressure on that spot until the glue sets.
It’s most sides apart from the top, I’ve reattached for now but will need to glue if doesn’t hold. I know some adhesive needs heating to activate so checking I hadn’t missed anything
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 80
