Model A1285 / 8 or 16 GB capacity
206 Questions View all
White Screen after I accidentally dropped my iPod nano 4th generation?
I accidentally dropped my ipod nano 4th generation on my ceramic floor and the screen went White :( it doesn’t show anything. Tried power off many times, but the Apple Logo doesn’t show? I even took all my songs off and saved to a file on my desktop then restored it to factory setting and still nothing is happening?? It’s still White Screen???
1 Comment:
I’ve tried it and it goes from white screen to black screen then white screen. No Logo.
by
Add a comment
With it hitting a hard surface, it sounds like the ribbon cable for the LCD may have come loose. If the LCD was broken, you’d probably see lines across it or black patches. The storage seems to be working and so the iPod itself is good. If you’ve already completed a hard reset with iTunes, try this before possibly opening it up:
“Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) 2. Now press and hold the Menu and Select buttons until the Apple logo appears, which may take about 6 to 10 seconds.”
1 Comment:
by
Add a comment
It sounds like you damaged the LCD and need to replace it. I found the part at idemigods.com they have the LCD in stock it about 21 dollars, they also have a battery in stock for 10 dollars if you would like to replace it while you are in there. I hope this helps
2 Comments:
Thank you Allan for your help, will do. But when I get these replacement parts, who can fix it for me?
by
Anyone who has some mechanical abilities. It helps if you have the correct tools and equipment to do the work. I am sure if you put it on Facebook or something like craigslist you can find someone but make sure they have good references.
by
Add a comment
Add your answer
Rosanna Sfraga will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 125
