Released on July 21st, 2018, the Huawei Nova 3i is an Android smartphone manufactured by Huawei, a Chinese multinational technology company.
17 Questions View all
Touch screen works but not in eRecovery when trying to reset
Okay guys so I bought a Huawei Nova 3i (INE-LX2) and the screen was smashed and not functioning. I replaced the screen and it’s pin locked (no way to figure out what it is) and when I tried to go into recovery it’s asking me to type ‘yes’ on the keyboard to confirm. The problem is while the touchscreen works when the phone is booted it doesn’t work when it’s in recovery. Is there a certain tool or program I can use on my computer to flash or reset it? Any advice helps!
Score 3
1 Comment:
Anch’io ho questo problema hai risolto?
by
Add a comment
If bootloader was locked, you can reset all data (pin also) via fastboot command - look at the seventh paragraph of this guide (sorry, I didn't found similar post in English).
2 Comments:
Sorry, *unlocked
by
I did my best to translate it and I tried every method on that list but it didn't work. Is there a way to flash it though USB update or fastboot? OEM unlocking and USB debugging are off, not sure about the bootloader though. Thanks!
by
Add a comment
In recovery mode you use the volume and power buttons to navigate to the option you want to select. Recovery mode is basically the same as safe mode in Windows. Only the bare bones of the os is loaded hence why touch doesn't work.
Add a comment
Thanks for the answer but in factory Settings you need the touch to enter 'yes' and I don't like it despite the touch working
Add a comment
Add your answer
Jakob will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 137
All Time: 6,626
