Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
55 Questions View all
Did I brick my GBA?
I was trying things and fiddling around with one of my gbas (not an sp), and tried attaching a rechargeable battery to it. Not one built for the system. It worked fine at first, but eventually the green light came on for split second and it didnt power on. I pushed harder, continuing to try to get it to work. Eventually, it wouldnt work at all. Now, there is absolutely no signs of power whatsoever. That gba was already in bad shape, so i’m ok with it being gone, but I decided to come here for any possible answers. I don’t know what to check for any shorts, and it would definitely be cool to fix it if possible.
Add a comment
1 Answer
Most Helpful Answer
Check if it’s just a battery terminal problem - anything that uses disposable batteries anyone can change is designed with reverse polarity protection if the designer has made it past basic engineering 101. If they’re bent, I would see if you can correct it, but depending on the amount of damage done add a little extra to it so there’s room to compensate for the damage. The negative terminals are spring based in the GBA and GBC and are sadly, easy to break if you abuse it the right way. That said, the reverse polarity diode can burn out with time so it doesn’t always save you but it’s usually not reverse polarity damage.
If it still doesn’t work, what I would do is find a parts GBA that HAS NOT been backlight modified so you know the board is original and replace the damaged terminals. This does require soldering, but if you can get a busted one for pennies to the dollar it’s worth taking a chance. Don’t spend nearly as much as a nice used one, so you may need to stand your ground on price depending on how stubborn the seller is.
Score 1
1 Comment:
There definitely seem to be no issues with the battery terminal. The battery terminal was fine and I suppose it to be an issue with the components that i must have fried.
by
Add a comment
Add your answer
Joseph will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 463
