3
Score
Asked
My MacBook won't boot, no start chime, just the DVD spinning sound.
I had to take my computer to work to be inventoried. I didn't turn it on. I brought it back home and now it will not start. When the power button is pressed I can hear the DVD spin, but no start up chime. The status light in the front is on solid, but dim. I got a boot disc in but it won't boot from it either and now I can't get the disc out. Any ideas????
THANKS
Update
For what its worth, I just was able to fix mine, with the help of this list.
For me the key was trying to start the computer with no RAM installed. After that succeeded, I went ahead and put a single RAM chip back in and it started up.
What started the problem was the main battery just got too depleted, which seems to have an impact on other parts of the system.
thanks everyone!
ABCellars, Brian, machead3, and oldturkey03
5
Score
rdklinc
15.3k
Answered
Accepted Answer
Hi! I'd first try to reset the PRAM, i.e. connected to AC and with the power off, hold down the power button for about 10 seconds until you hear a tone and see the sleep light flicker.
Next, try reseating the RAM, and test the slots one at a time by booting with one empty, and then the other.
Is the screen black or white, and if it's white, are there any icons on it? If white, try booting while holding down the option key and let me know if you see the option menu.
Hello, I tried this but I never go the tone. The sleep light did came on. I will try the ram test tonight when I get back from work. The screen is black, nothing on it at all. I tried the option key while booting, I got nothing... THANKS!
You were correct. I had a change to remove the memory, booting, re-seated the memory, and booted again. It is working. I really appreciate your help!!! THANK YOU!
I guess I spoke to soon. After posting this above message I closed the laptop. When I came back, it would no longer run. I was getting the same thing described above. I tried to reset the memory again and it would not work.
rdklinc said > Next, try reseating the RAM, and test the slots one at a time by booting with one empty, and then the other. My symptoms with one bad RAM module were: - display very briefly flashed on but then stayed black - No chime - Optical drive kept doing this brief mechanical cycling over and over, as if something stuck in it - hard drive spun up but didn't sound active. - sleep light stayed on solid Bravo!! Thank you. Rich
3
Score
rj713
33.9k
Answered
I don't know if this will work but try setting the SMC. Ralph
3
Score
remacberli
7.3k
Answered
Just a thought, but something i like to try in cases like this: Remove all RAM and try to start it. If the computer starts error beeps you know that the firmware chip is alive. Start troubleshooting from there. It's all too easy to just say you'll need a new logicboard.
Many thanks for this comment :) After several days of searching forums, this comment has given me hope that maybe there is still life in my macbook pro. I tried this and indeed the computer started to sound error beeps, so the firmware chip is alive. Does this mean that my logic-board is not dead afterall? When you say "start troubleshooting from there" I'm not sure what the next steps are for me to determine what is wrong with my mac. I've tested the ram, the hard-drive, the battery, all good, but it still won't start. I've also checked HD connections and DVD connections etc. etc. No luck as yet...
2
Score
Charles Fisher
349
Answered
Hello, I've experienced this same issue. Now, I have the
A1151 model (first generation of Macbook Pro) which does not have the NIVIDA video chip. While there are a lot of things that could cause this problem I take it that you have not opened up the top cover case. If you did then try these steps: remove only the two "allen type screws" completely (located behind the memory cover plate) also remove the four (4) screws located at the rear bottom side. Then start the machine and if it boots normally then just let it set idle for at least an hour. If all is well shut it down and wait for 30 minutes then reboot it again, let it just idle without logging in. If it stay up without shutting down then you know it is something pressing against the logic board underneath causing an automatic shutdown issue. If you have success, reinstall the 2 allen screws first then reinstall the back 4 screws only 2 at a time (the two closest ones on the same side). Then start the machine and repeat the idling process. Remember, this procedure is mainly for those who have gone inside of the machine to remove and reinstall the logic or I/O board for ANY reason. It will not hurt to still follow this procedure. If this clears up your issue, celebrate; you have saved yourself a boat load of money.
Score
Juan
13
Answered
The same issue happened to me and I found that by re-seating the interneal connectors for the DVD and the HD solved this issue! I spent several hours reading up about this issue and it was never mentioned anywhere. Based on what I had read I thought had to be my logic board but it WASN'T!
I read in several places that if the following conditions occur then it 'had' to be the logic board
(1) No startup sound
(2) Solid power light (not flashing)
(3) PRAM and SMC/PMU reset don't work
(4) RAM is compatable and correctly seated
If you can't get your system to work with the above you should check any internal connections to see if they are causing your issue, it was for me.
0
Score
LadyAviato
13
Answered
I am having the exact same problem as well. After running all the troubleshooting guides, I broke down and called Apple Support. After having me re-run all the things I had already done in the troubleshooting
Thanks, Holly
Follow-up: So, I took my Mac to the Apple store. They ran a few diagnostics and what-nots. They said the absence of the chime at start up means that the logic board is bad. They quoted me a "flat rate depot repair of $310 + tax" to fix it. I brought it home to check here first. The guy at the store told me a new logic board was $800 (same price here) so I'm not sure why the repair rate is only $310. Refurb? Maybe. I intend to find out before I take it back. I love my Mac, but in the 2 1/2 years I've had it, I've already had to replace the fan and now this too. I have a 10 year old Fujitsu that stills runs...why can't my Mac be like that? Anyway, the guy at Apple checked my serial number because there is some sort of recall on some models for logic board issues...but not mine. Figures. Might be worth checking into for rest of you with no start up chime! Best of luck!
Sometimes machines will chime again if you reset the PMU/SMC and PRAM. This is because the audio can be set to the lowest possible level (mute), but doing the resets restores it to a default that is audible. Or that's my theory, anyway. As for the price difference, Apple has two means of repair -- doing it themselves, or sending it to Depot. Depot is a partner of Apple, and they are cheap, as you've noticed. Apple itself is prohibitively expensive. Whether they offer you Depot or Apple is often a matter of discretion. If they like you, they offer Depot, and if they don't like you or the repair is not worth it, they give the Apple price to scare you off. I always ask for a Depot repair, at which point it's pretty hard for them to deny me. A Depot repair comes with a comprehensive 60 day warranty (or is it 90?), and they do a diagnostic on the machine as well, so there's a good chance you won't have more problems. After all, you're replacing the board, which is essentially the whole computer.
Holly, I went and bought this computer: http://usa.asus.com/product.aspx?P_ID=8j... I donated the broken MacBook Pro to a friend who might be able to fix it. It costs TOO MUCH to support and use. The repair center was going to charge me $500.00 + labor. And that wasn't a guaranteed fix. It's just too much and not worth it, when you can buy a cheaper more powerful PC computer. COmputers are getting to the point where they cost more to fix than what they are worth, like VCRs did. It's cheaper to buy a new one than to fix it. -Chad
chad,
But Chad, keep in mind, no reputable repair person who knows what he is doing is going to charge you $500 plus labor and not give you any kind of guarantee. That is not an accurate reflection of the cost of fixing an Apple product; rather, that is a reflection of the likeliness that the repair person you took it to was an incompetent moron, and he was probably insecure about his ability to fix the machine, and therefore passed the burden of his incompetence on to you in the form of a ridiculous price and no guarantee. You may have been able to fix the machine with a new DC-in/sound board for $60 and a couple hours of your time -- that is what iFixit is all about. And sure you can get a cheap throwaway netbook for a couple hundred dollars, but you get a $200 experience as well, and nothing at all comparable to a MacBook.
0
Score
Answered
i'm struggling with the same problem. it started yesterday, but at some point after doing all the reset procedures 10 times each, moving ram chips from one place to the othe for a dozen of times, the computer suddenly started. and it was working perfectly ok through the whole evening, and even in the morning. when i came home in the afternoon though, it was dead duck again.
0
Score
jiml13
Answered
0
Score
serge
Answered
After reading all this thread and playing around for a whole day with my broken MBP, the light in front seems to stay on light not very intense, not booting after the optical disk sound problem.
The whole thing revolves around playing around the RAM modules, not the battery, not the screen, not the reseting, just remove and put back the RAM in one of the slots luckily one of the slots is still good. No need to do anything else, as soon as you see the dimmed light in front (where you open your laptop) it means the RAM is not properly set in the slot. Once the light goes away it will boot normally (after of course making sure the RAM module is actually good).
I seem to be able to pin point the problem as being a damaged memory RAM slot not the RAM itself but the slot. I am able to boot my MBP by putting only one RAM module in the lower slot, as soon as I put another module in the upper one the problem comes back (half lit light in front where you open the screen). It may be just a problem related to the contacts or either the solder have melted around one of the pins so the current is not passing anymore. Looking very closely at the small pins some were a bit loose... So to my best knowledge this is the problem. but how to replace a broken slot?
I personally can live with the only 1GB running MBP. I have the A1150 model back from 2006 running on 10.6. But still wondering how I can fix this by changing the memory slots altogether. Can I buy and replace that piece?
0
Score
Answered
I am having this problem with an early 2007 first gen macbook pro. I don't get a startup chime and the screen doesn't turn on, but after I turn the machine on I have found that I can access the computer through my network via another mac. This suggests to me that in some basic way the computer is running. Any advice?
~Jesse
If one of these answers solved your problem please hit the accept button so that it may be removed from the unanswered list. Thanks
mayer,
OK - I had the same problem and tried ALL of the fixes; without success. I didn't even get the boot error sound with the RAM removed. At that point, I was sure that I was looking at a dead logic board. Since the optical drive was spinning, I put in a system CD and tried booting holding down the 'C' key. Nothing happened. After a few more attempts, and thinking i was done for, I booted it, holding down the CD eject key; wanted my system CD back. Lo and behold, it booted! i have looked at many forums, but have never seen this solution. I have serviced many mac, over the years, including changing out drives, CD cards, screens and even a logic board in my first PowerBook G4 - so it's not like I am a dummie. For the life of me, I cannot figure out how this fix worked. I have rebooted it three time, and all appears well. We shall see...... Thanks to all who have contributed
Tomas Jones,
Hello-a1260, will not boot, as above. (1) No startup sound (2) Solid power light (not flashing) (3) PRAM and SMC/PMU reset don't work Bought another mb pro-same model a1260, replaced parts from working unit one at a time, hdd, pram battery, ram (all configurations) , temp sensors, input power card,etc. Would not start until I changed the logic board. I am not savvy enough to diagnose circuit board component failures- but the board change fixed the MB Pro. Love having it back!!!!
John the Baptist
john essigmann,
