Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
435 Questions View all
Mid 2007 iMac won't recognize any keyboard or mouse
Hello,
I have a mid-2007 iMac that I upgraded to a core 2 duo T9500, aswell as switching the original hard drive for a 2.5 in 1 tb hard drive. I original received it running El Capitan, which I then upgraded to catalina, after some time I moved to Linux mint, and I have now after much work reinstalled MacOs and I am currently running MacOs High Sierra. The issue I am having is that none of the keyboards or mice that I plug into any of the ports are being detected, and it is effectively dead in the water, as I can’t log in. The only time I can get them to work is if I am in the boot picker, any other time they simply aren’t detected.
Has anyone else had this issue, or heard about it?
Add a comment
1 Answer
Chosen Solution
Are you able to create an external bootable FireWire drive from anther Mac system with Lion OS-X 10.7.5 which is the highest level of OS-X you can run on this system.
From what is sounds like you pushed the system beyond what it was designed to run. Pushing it to Catalina I think did you in. You’ll need to return your systems EFI if you can’t get the external boot drive to boot up.
Score 1
7 Comments:
I don't have another system with Lion, as this system was given to me by a relative, but if I got an install disk with Lion, would that work?
by
Sure give that a try! Are you able to boot up under it?
by
Yes, I can get to the booot picker, it just freezes up once I'm on the lock screen.
by
Not good ;-{
Thats a sign the PCH chip has failed, the systems EFI maybe the cause.
This chip interfaces between your drives PATA (optical) or SATA (HDD) and the CPU.
by
I'm guessing theres no way to fix that at home.
by
Show 2 more comments
Add a comment
Add your answer
alexbiery11 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 215
