Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Questions View all
Came with Seagate Hard Drive, find 2TB replacement?
My Mid 2010 i3 3.2GB 21.5" iMac has a 1TB Seagate ST31000528AS. I have to replace HDD's with the same manufacturer for the thermal sensor, right?
Where can I find a Seagate 2TB HDD that I can swap out with the original?
Thanks in advance.
Add a comment
Chosen Solution
Yes you are correct this does need same manufacturer. I believe also it must be of the same series, which means you are going to want to find a drive to the tune of ST32######AS. I saw a few for reasonable prices on Newegg. I believe this is what you are looking for.
Score 4
2 Comments:
If you are having problems with your current hard drive it is still under warranty by Seagate.
by
Always have clear and informative answers. +
by
Add a comment
Thank you for the reply, that explains what I need to know.
Nothing wrong with the current HDD, just need more space.
I'll pop over to Newegg and check it out.
Add a comment
Add your answer
Dave will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,788
