Why is my bt speaker turn off at high volume?
When i turn the volume up around 70% it turns off, it plays the tune that its turning off though, and also does this even with the charger plugged in
I had the same problem on my JBL flip 4..I do not know what blue tooth speaker you have but I will share this. When I use a fast charger or any other charger except for the one that specifically came with the charger, mine does the exact thing as yours. My first suggestion if you do not have the plug end ( as most come with some form of a USB plug) research the specific amps or power that your speaker needs. This is actually crucial if you value the longevity of your battery. Another place to look is your cable. I've bought many after market cables and I can promise you ( with out getting all tech specs) your cable does matter. Also if you plug your speaker in when it's at a low battery it will shut its self off thinking that the current is insufficient to both charge and at the same time play your speaker……..I hope this helps :)
My speaker does that too, so I disconnected the battery and threw it away and now it's running on AC but, one problem..... It's micro B port, I used my Xiaomi 18W charger which came with my phone, and 0.2 amp charger (not sure about the watts) also an aftermarket 15 watt charger, I thought the solder came slightly off so, I took the pcb and the driver out of the casing and found all the solder were fine, the driver is also fine.
Help.....
Sold it but thanks for the answer , very informative and I'll keep that in mind for future use of other devices
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 87
All Time: 4,807
