0
Score
Avatar
Jason Appel
Asked
Green Fuzzy Screen on ipad on occasion
History
Hello,
I have an iPad 1. The screen will occasionally go green and fuzzy. It seems that all the colors aren't showing correctly. Black and white seem to display fine.
This will happen and it will suddenly go back to normal after a while.
I thought this was the LCD going bad so I replaced it.
A few days go by with the new LCD installed and BAM the Green fuzzy screen is back!
It does this about 40% of the time.
Any ideas?
Edited by: David Hodson ( )
Post Answer
0
Score
Avatar
David Hodson
35.5k
Answered
PermalinkHistory
Sounds like some sort of hardware problem with the graphics, from what I've seen on various forums. It's a known problem throughout the iPad lineup, so you might consider taking it to your local Apple Store and seeing if they'll swap it out for a new one.
Thanks David. I'm not the original owner of this iPad so I'm not sure what Apple will say. I would like to fix it myself but will go to Apple if I can't find a solution. Best Regards Jason
Jason Appel,
0
Score
Avatar
Terry Arcia
Answered
PermalinkHistory
Okay, This happened with me. Went to Mac store and they said this happens when u drop you iPad. I didn't think I dropped mine, but they showed me where the dent is... Must of dropped it! They told me that I was SOL. I got home and it got worse. I read on a Mac forum ain't it said it whack your iPad. I whacked it, it when black.... I whacked it a couple more times it. Came back worst... Then I whacked it again and now it is working fine... For now.
0
Score
Avatar
Adam Shawyer
Answered
PermalinkHistory
My 12 month old son dropped the ipad which i left on the table. The screen went green and fuzzy. I picked it up and pressed on the screen in the corners - it then worked fine, but it is delicate now which leads me to think that the display cable is loose.
Add Your Answer
