The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Questions View all
Press the R-Trigger and my System will shut down
In the Question below is my Problem and i will need help to fix it.
But i am not good in repair something else.
Can it be that a cable is broken or what could it be?
Please help me.
For my poor english,i´m from germany ;-)DS
Add a comment
1 Answer
Chosen Solution
You have a short somewhere in the cable that the trigger switch is attached to. Here is the part You need. Here are instructions on how to replace the part.
Nintendo DSi SD Ribbon Cable Image
Product
$24.99
Score 2
3 Comments:
THX for help.I thought that my english is bad but i understood what you mean^^and is a short somwhere in the cable but how can this cause?
by
The ribbon cable the r-trigger is on contains the SD Card slot, the left and right trigger button contacts, and also the volume control buttons. If the positive electricity from the r-trigger goes to the positive electricity for the volume or to the SD card reader there is a problem because voltages have changed. Your problem with it shutting down may even be water damage and the connector on the motherboard where this cable is connected may have corrosion on it. If you find that to be true let me know I will cover how to clean it with you.
by
There is not a water damage.if it is a short on the cable how can it released?the Dsi wasn´t fall down on the ground or something else.I hope that the new cable is the answer for the problem.what did you think?
by
Add a comment
Add your answer
Sascha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,170
