Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
digitizer ribbon cable ZIF sockets
Hi guys, I´ve followed your steps to change the ipad front panel but I messed up the “digitizer ribbon cable ZIF sockets” trying to “prying up on the hinged retaining flaps” Can I buy just that part? the front panel its perfect but i miss-understood the steps and broke those connectors…. Did I need a new complete logic board? thanks a lot!
Add a comment
1 Answer
Chosen Solution
Replacing those connectors requires some micro-soldering so unless you have experience doing this kind of work, it is not really a DIY repair.
A repair shop that specializes in micro-soldering repair should be able to do this for you. Depending on where you are located, you’ll need to consider if it is a worthwhile investment for such an older device. Alternatively, you may be able to find a used logic board for less than the cost of the repair.
Score 3
1 Comment:
Thanks a lot!
by
Add a comment
Add your answer
joao will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 62
