Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Questions View all
iPod displays folder icon error
I have a 4th generation 20gb iPod (mono) that is displaying the folder error icon. So I have replaced the logic board. I have also replaced the original drive with a iFlash-ATA1 adapter and a Samsung 128gb SD.
After all that, the iPod still displays the folder error and my computer does not see the iPod when it is connected.
Any ideas about what I should/can do next?
Thanks
Add a comment
1 Answer
Most Helpful Answer
@sneatonscott your computer most likely will not recognize it since you have no firmware/OS on the iPod drive. I suggest you try it with a regular HDD first and then see what it tells you.
Score 1
2 Comments:
I did try that first. I had the same problem. But I’ll try it again.
But if nothing changes, do you have any other suggestions?
Thanks.
by
Have you tried to place it into diagnostic mode with a HDD installed?
by
Add a comment
Add your answer
Scott Eaton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 163
