Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Questions View all
iPad 2 wont connect to open WiFi network
When i try to connect my iPad 2 to the guest WiFi at my school, it just has the loading circle and wont connect, however it will connect to my home WiFi perfectly fine showing the little check mark. i have tried factory resetting the internet options and it did not work.
Update (01/16/2020)
PROBLEM SOLVED!!! After a quick factory reset on the iPad it will connect to my schools WiFi
Add a comment
1 Answer
Most Helpful Answer
Have you tried opening a browser? Usually with these cases you are required to login some other way besides using just the Wifi password, especially at a school. Check with your front office, they probably have the login information (unless it's not actually a guest account for students, in which case you're probably out of luck by normal means)
Score 1
2 Comments:
i have tried opening both chrome and safari, and going to an HTTP website such as www.cnn.com but it doesnt redirect to the internet login page
by
i have also used this guest WiFi perfectly fine on other devices such as my phone, and the school uses it on some of their computers aswell
by
Add a comment
Add your answer
Vipaha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 78
