Right earbud not charging
Hi, I've had my JBL TUNE 120 TWS for about 6 months now. Originally after a while the right earbud wouldn't turn on when I pulled it out of the case, now it just thinks I'm pulling it out of the case every 5 seconds and so turns on and doesn't charge. I think it's a problem with detecting whether it's connected to the charger of not. Does anyone have any ideas?
Thank you, Matthew
Score 1
Add a comment
1 Answer
Hi Matthew! I hope you've found a solution before this has gotten to you. I've run into the same problem lately. I found the problem to be a dirty connection between the earbud, and the dock. I recommend taking a Q Tip, or toothpick and soaking it in 70% or higher rubbing alcohol and using that to clean the connections.
Add a comment
Add your answer
Matthew Lloyd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 300
