The fourth version of Sony's famous Walkman cassette player, the WM-4 was introduced in 1983.
10 Questions View all
Sony Walkman wheels not spinning
Hey everyone!
I have a problem with a mid-80s sony walkman (Sony WM-31), as the wheels don’t spin when I press play. The belts seem fine and the cylinders spin when I manually move the cylinders the belts are attached to. What’s the problem here? Could it still be the belts, i.e. they’re too loose maybe?
1 Comment:
Edit: Motor does not work.
by
Add a comment
1 Answer
@yaboyenrico you are not telling us if the motor actually spins. Start with that, then the belt. Here is the SM for your Walkman which should help you out in getting it repaired. Sony WM-41 SM
Add a comment
Add your answer
Enrico B. will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 23
All Time: 924
