The Huawei P20 Lite is a budget, yet powerful, smartphone from tech giant Huawei. It features dual rear-facing cameras and an amazing display.
48 Questions View all
USB port unresponsive after dropping in water
dropped the phone in water for a brief moment, it was immediately taken out of the water, and dried with the dry rice technique. Worked fine the day after but now the charger usb port is unresponsive and does not charge or seem to recognised the phone when connected to laptop
Add a comment
1 Answer
Most Helpful Answer
@jzed12345677 “the dry rice technique “ is bogus and nothing but a urban myth. It does not work. Using Rice for a water damaged device is the equivalent of not doing anything. Read all about that on here Don't Put Your Device in Rice. Here's Why...
For now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. The very first step I would take is to disassemble your phone. Use something like this guide to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use distilled water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned or use an ultrasonic cleaner if you have one available to you Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Huawei P20 Lite Display (with frame and battery) Image
Guide
Huawei P20 Lite Display (with frame and battery) Replacement
Difficulty:
Moderate
25 - 30 minutes
Score 2
Add a comment
Add your answer
JOSH NIECHCIAL will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,013
