Repair guides and support for top and front loading Whirlpool brand washers.
427 Questions View all
Washer stops early in spin cycle
I have a newer whirlpool washer and it worked fine for a while and now it is stopping early in the spin cycle leaving the clothes sopping wet . It is like it wont spin up all the way or as fast as its suppose to once it starts going so fast it stops and just starts draining no matter how many clothes or what size load it has ?
Update (10/07/2019)
It is a top loader btw..
Score 1
7 Comments:
Curtis Cole what exact model number is your washer? Explain this "once it starts going so fast it stops"
by
Im not sure where can i find it it just says whirlpool on the front no numbers or letters
by
Toploaders should have it somewhere on the rim under the lid. The issues you are describing sounds like a clutch issue. We need to know what model your washer is so we can check it out further.
by
So the mod is WTW5000DW1
by
I have this exact same problem with a Whirlpool Cabrio top-loader. Model # WTW7800XW2. Can you help?
by
Show 2 more comments
Add a comment
1 Answer
Its probably an issue with the computer in the washer. Call the manufacturer.
Update (10/07/2019)
When you pick up the lid, on the bottom left of it there is a screw. Sometimes if you tighten it, it will work.
Add a comment
Add your answer
Curtis Cole will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 54
All Time: 2,870
