Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
46 Questions View all
How do I disconnect the oil pressure sensor electrical connector?
Because the oil pressure sensor is at the back of the engine on my 2003 GMC Yukon XL Denali 1500 6.0L, I can't see it but can feel it with my hand. I'm having the worst time trying to lift up on the electrical plug's clip with my finger and there isn't enough room to try and fit a flat blade screwdriver back there. Is there an easier way, or some tool that will help disconnect the plug?
Add a comment
1 Answer
https://www.youtube.com/watch?v=x_yjZ3mC...
Does this help much, if it is the same type of connector release then it appears that you might be able to reach around from either side of the back of the engine, if laying up on the engine, you might be able to reach around with both hands, one from each side. Good luck.
1 Comment:
If you are going to replace your sending unit, be sure you get the correct type, for example, it has one wire or three wires, it may not be the exact same dimensions for the overall unit, but the connectors are all the same but the number of wires can be different, beware!!
by
Add a comment
Add your answer
Cullen John Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,721
