Samsung's tenth-generation flagship "phablet," featuring its trademark S Pen stylus. Released August 2019.
56 Questions View all
Can UV Glue enter the device and get past its waterproofing?
I was trying to install a tempered glass screen protector that uses UV glue to set it to the screen and my phone ended up getting like soaked in the stuff (it would just run off the edges and not evenly go under the screen protector) (i ended up just removing the screen protecter and went back to plastic)
is it possible that the uv glue was able to go past any of the waterproofing barriers in the phone? as the phone is certified ip68 water resistant. i tried cleaning up as much as possible. i know it entered the pen area inside as i could smell it strong on the s pen.
Score 1
2 Comments
Did you face any problems after that?
Does your phone still remain water resistant?
by
@mmimmunna It did work after that but i did end up getting the phone replaced as i believe i either broke the screen or something happened to it i dont remember though.
by
Add a comment
1 Answer
Chosen Solution
It wont get past the waterproofing itself, its just gonna seep thru the crevices where glass and frame meets. In my experience when this happens its almost impossible to clean it off without the glass looking a little “off". If you had to do this again on your Note 10 my advice is you only use 1/3 of the glue in the bottle, it will take a while to spread but its better than it leaking off to the frame. If it dont spread anymore after 30 mins or so you can gently squeegee the glue to the rest of the glass. Just be patient and careful. Also, if you want the fingerprint scanner to keep working 99% of the time the glue has to be super thin. Hence 1/3 of bottle only, and squeegee to spread the glue out. I've gone thru 20+ different uv screen protector installs, 3 different rear glass replacements and TWO screen replacements because I got crazy and didnt wanna give up that fingerprint scanner for a screen protector, but the glue kept creeping thru the crevices leaving permanent marks on the phone making it look ugly. Ick.
Score 1
1 Comment:
So nothing is gonna happen on the s24 it's gonna get out at some point
by
Add a comment
Add your answer
Minion Mayhem will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 95
All Time: 4,888
