Radio controlled formula superbuggy by Nikko.
2 Questions View all
Problem with Nikko Landshark
Bought a Nikko landshark without battery. So i connected a other i had lying around an put it to on. IT moved for couple of minutes and the it stuttered and stops. The battery is now recharged and is does not want to move.. I dont see lose wires or anything burned and dont smell anything. Does somebody knows wat the problem can be?
4 Comments
does your battery voltage match the original one?
by
No, its different
by
More or less, please provide us with more information (values).
by
Its a Landshark. I got part removed and disconected battery tray. I place 8.4 battery on the wires and then i was driving with for couple of minutes. Then is stopped and now it does nothing. Nothing is burned as far as i can see. And all wires are good and not lose
by
Add a comment
1 Answer
Chosen Solution
Dennis the original battery was a 6.0V 620mAh so you need to tell us what battery you are putting in. After that you need to use your multimeter and check for the power leads etc. going to the main board. Without the basic information we can only guess.
Apparently the Landshark was known for very poor battery life
Update (09/16/2019)
It's a 6 volt system and you used a 8.4V battery? Check your power board for burned components (you will have to measure the values ) and check your motors to see if they are still working.
Score 1
Add a comment
Add your answer
Dennis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 135
