The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
82 Questions View all
What error 0xC1 means on printer EPSON WF-7620 and how to fix it?
I got this error 0xC1 on an printer EPSON WF-7620, the display message suggest to turn the printer off that then on again. I did but the error coming each time preventing me to use the printer and its keyboard controls.  Any idea what this error menas?
Add a comment
Chosen Solution
@morend error 0xC1 is a CRCM access error. Causes for this can be :
  • Ink cartridge failure
  • Holder Board Assy failure (CSIC Terminal failure/CR Contact Module failure)
  • Main Board failure
  • Cable disconnection
Start by checking on those. Most likely would be a failed ink cartridge. Could be the print head so check on this as well
Score 1
Add a comment
I used to get the error 0xC1 on my Epson printer quite a lot when I first got it. At first, the problem seemed unknown, but after taking consultations from the experts, I came to know that it could happen due to mainboard failure or a problem with the cable connection. To resolve this problem on my device, I usually follow the following steps. You can also try them to fix the issue on your Epson printer.
  • The first step is to open the printer scanner.
  • Next, you should inspect the FFC cable connected to your device.
  • Then, you are required to reassemble your Epson printer.
  • Furthermore, check your system's mainboard.
If all these steps are unable to fix the 0xC1 error, then getting help from someone else could be a great option for you.
Add a comment
Add your answer
Daniel will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 16
Past 30 Days: 42
All Time: 6,126
