Power button gets stuck from time to time
Occasionally, power button gets stuck on triggers double-click when pressed once. I suspect this is a “mechanic” issue since the phone fell down several time.
Is it easy/makes sence to disassembly Nokia 6 and fiddle around with power button to try fixing the issue?
Add a comment
1 Answer
this would require you opening the device carefully with the right tools and using a tiny piece of double sided tape to hold button in place where it belongs before carefully closing phone insuring you dont dislodge button, ive personally cut delicate ribbon cable attaching button and had to spend $2 us to replace
Add a comment
Add your answer
Dima Naboka will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 337
