Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Questions View all
What should be my next step?
I’ve replaced the HDD, the board, and the battery(Twice) and I cannot get this thing to boot. When I initially replaced the first battery I was able to get into diag but it died and it will never charge (even though sometimes it would show the charging symbol). After fiddling with it for a while I assume I killed the battery beyond its low charging point so I decided since I got the exclamation point folder icon to try and new logic board. That is where I am now and it is just flashing the apple logo for half a second and will not do anything else. Should I continue to fiddle with this thing or should I just ebay a 5.5 gen and start from there? (I was going to restore it as it was a graduation gift so it has sentimental value but I can always just keep the body around as a paperweight)
Add a comment
1 Answer
Most Helpful Answer
@gabardine since you already replaced most parts it seems that there are other issues. I strongly recommend to get a AC FireWire charger and a FireWire cable for this. Charge your iPod with a Firewire connection. It will also require that to complete a restore/update. You will need a firewire adapter in order to complete restoration.  Let us know what you get with the FireWire setup before giving up.
Score 2
Add a comment
Add your answer
T Blevins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 34
