Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Questions View all
Frozen On Apple Logo No Matter What
Hey everyone. I recently found my old iPod Classic from about 10 years ago at least. I plugged it in after searching for an old 30-pin charger and to my surprise, it actually the “Charging Battery” icon. However, after about 10 minutes of charging, it goes to the Apple logo and than does nothing. I’ve tried resetting it, but it doesn’t even reboot, it just stays at the Apple Logo as if I’m not even touching any buttons. I’ve also tried syncing it to iTunes to see if it would recognize it, but nothing happens. The only way the Apple logo disappears is if I disconnect it and let it die after a day. I’m starting to think the HDD might be ruined, which isn’t a big deal at all, I just figured that it would be cool to use for a bit for nostalgia. If anyone can help, please feel free to respond. Thanks!
Add a comment
1 Answer
Most Helpful Answer
@edmonddant
you did not tell us if your computer “sees” your iPod when you connect it. If so, try and place it in disk mode and see if you can access the drive. You can even try the diagnostics mode as explained on here
Let us know what you get.
Score 1
4 Comments:
Hi, thanks for replying! When I connect the iPod to the computer, the computer doesn't recognize it, but I'll definitely try to see if I can put it in "Diagnostics Mode"
by
Hey! When I try to put it in "Diagnostics Mode", I get an iPod icon with a triangle with a exclamation point inside it.
by
Could be a HDD error as well as a board error. If I remember correctly you can get an inexpensive adapter for your HDD to IDE and then connect it to your computer. There you can then check if your HDD is accessible. The 4th gen still had (required) a lot of Firewire support so I would at least try a firewire cable and charger for a restore.
by
Thanks so much for your help!
by
Add a comment
Add your answer
Edmond Dantes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 50
