The Acer Chromebook 15 CB5-571-C09S is a white laptop created by Acer Inc. and operated by Google Chrome. This laptop was released in March of 2015 and has a 15.6" screen. It can be identified by the model number CB5-571-C09S.
4 Questions View all
The top half of my laptop is severely warped
Someone gave me a Chromebook 15 recently. The top outside is severely warped causing it to not close flat and there is a bump through the middle of the outside the width of the laptop. The screen is still flat however, is no longer sealed around the edges in spots. Other than that there are no cracks or breaks anywhere on it. I haven't tried to power it up yet to see what, if any damage that way yet, I wanted to get some feed back on this first .
Add a comment
1 Answer
Chosen Solution
If I'm reading your post correctly, it sounds like the only problem you're seeing with the laptop you got is that the top cover, the one the LCD is attached to, is warped but does not appear to be otherwise damaged, and the LCD screen itself appears to be intact, is that right?
Generally speaking, if the LCD is intact, chances are pretty good that powering up the computer shouldn't cause problems; if it was my computer I'd give it a shot.
I've started work on a guide to replacing the display housing, but it's not far enough along to be helpful to you, plus it's for a CB3-532 rather than your model. However, I do have a guide for removing the display assembly that looks like will work for your computer: Acer Chromebook cb3-532-c47c Display Assembly Replacement - iFixit Repair Guide
Once you've got the display assembly off, follow the screen replacement guide for your computer: Acer Chromebook 15 CB5-571-C09S Screen Replacement - iFixit Repair Guide
After that, it shouldn't be too hard to figure out how to disassemble the hinges and pull the camera and antennas and swap them to a replacement housing.
Hope that helps!
Acer Chromebook 15 CB5-571-C09S Screen Image
Guide
Difficulty:
Moderate
5 - 10 minutes
Acer Chromebook cb3-532-c47c Display Assembly Image
Guide
Difficulty:
Moderate
Score 1
Add a comment
Add your answer
Michelle rains will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 198
