Repair and disassembly guides for Garmin GPS devices.
324 Questions View all
Replacing the digitizer glass
I just purchased a replacement glass for my Garmin Edge 800, but it is just the glass and not the glass in the frame. How do I remove the cracked glass from the frame and install the new one? The original appears to be glued to the frame
Score 1
Add a comment
1 Answer
@dwiener
use a good hair dryer or a heat gun on its lowest settings. Move the hot air along the sides of the digitizer to soften the glue. Once soft, use a thin tool to replace the digitizer.
2 Comments:
I’m trying a hair dryer. The case is getting hot, but the glue doesn’t appear to be softening. About how long should it take?
by
@dwiener big depends on the glue they are using. It is most likely a adhesive strip. Try a guitar pick and loosen it when the heat is relatively high without melting the case.
by
Add a comment
Add your answer
Dennis Wiener will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 320
