2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Questions View all
Installed new battery but battery not charging even after SMC reset
Purchased a replacement battery from iFixit but the battery is not recognised. Have tried an SMC reset but this hasn’t remedied the situation. I attach a screen grab of the coconutBattery app running: battery has 0 charge cycles.
Add a comment
1 Answer
Chosen Solution
Your screenshot uploading failed, so please update. Would be interesting to know why you replaced your older battery, but if that one didn’t charge either, you might have a logic board issue at charging circuitry. New batteries are usually sold at about 70% capacity charge, thus it should have worked out of the box even without charging it. If you used an aftermarket charger that might be the original culprit, but such issues may happen with an original magsafe nonetheless. Hard to say it for sure without testing, but you might need a component level repair or a board replacement.
Score 2
Add a comment
Add your answer
Steen Oois will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 71
