Devices that create three-dimensional objects from digital files through additive processes using various materials such as plastic, metal or resin.
71 Questions View all
No clue how to get proper values for the thermistors.
Hihi! haven’t been here in quite a while.
Anyway, I’ve got a problem. I cannot seem to figure out the proper values for the thermistors in my 3D printer.
I have spent a few hours researching, and found I need a Beta Value and an R value. I know the thermistors are 100kOhms. (according to Reddit, https://www.reddit.com/r/3Dprinting/comm... ) And according to Marlin Firmware tables for said thermistor, it has these values:
Using the values of
“M305 P0 T100000 R1000 B4200 ; Set thermistor + ADC parameters for heater 0
M143 H0 S120 ; Set temperature limit for heater 0 to 120C
results in tempature readings of 38C when it should be roughly 22C
Hopefully I phrased this in a way thats not as confusing as it is to me.
Any help is appreciated.
Thanks!
Add a comment
Chosen Solution
I figured it out. There was a preset option you could select and with a little editing to it I was able to make it work. here are the Sensor Values that are working:
100kOhm Thermistor
Beta: 3988
R: 2200
Score 1
Add a comment
Most Helpful Answer
@captainsnowball brother you are not giving us much to work with here:-) No pictures of the part? Good to see you on here. Anyhow, the thermistor you are looking for should be a B57560G1104F000 - Thermistor, NTC, 100 kohm, B57560G1 Series, 4092 K, Through Hole, Radial Leaded. Here is the datasheet NTC thermistors for temperature measurement, glass-encapsulated sensors, standard type
Score 2
2 Comments:
Thanks! I'll look into that tommorow afternoon. I'll update with pics as well if I have no luck.
by
@captainsnowball no worries about the pics. Take your time and focus on getting the part. Best of luck to you. Don't be a stranger.
by
Add a comment
Add your answer
Aiden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 794
