This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 Questions View all
Screen messed up after isopropyl alcohol. Fixable?
So after I cleaned the board with isopropyl alcohol after some water damage but I cleaned some metal parts off the screen because there was some corrosion. After I did that the phone now starts up but the screen now looks like this now. Is this fixable or is it permanently going to be like this?
Add a comment
1 Answer
You have moisture in between the diffuser layers of the backlight. You're probably looking at a screen replacement or at least if you have the tools and skills a backlight replacement. It looks like a replacement screen assembly is only about $30 with the frame so that probably your best option as long as your confident the phone will work still after the water damage repair.
Add a comment
Add your answer
jimmysofat6864 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 206
