Released on February 25th, 2013. 10.1" Tablet with Android Operating System, ARM Cortex A-7 Quad Core Processor.
28 Questions View all
My tablet is not charging and quickly heating
i had broken my charging port.after i fix it.i have check it throug come 5v positive line.. but it not charge.. i want to know how to bypass charging port.. and i want to know it has a any other solution. thank you …
1 Comment
thank you..!
by
Add a comment
1 Answer
Most Helpful Answer
Is the replacement port the same amount of pins and the same orientation? Ones that are flipped upside down can’t be used as they route the pins opposite to where they are supposed to link to the board.
Another thing I do sometimes if needed is jump start the battery I inject 3.7-4.2v on the + and - of the battery’s to externally charge them via a DC bench power supply. Voltage may vary depending on rated voltage of the battery.
Score 3
Add a comment
Add your answer
Kelum Aruna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 93
