My 2004DS Club Car no longer goes in reverse; forward ok
Why can’t I go into reverse. Mechanical sounds ok but no reverse
Update (05/05/2019)
Please be specific about reversing forward/reverse connections. Where are they?
Leonard Spinoso until we know for sure what type of cart you have, here is a simple check about the possibility that this is a forward/reverse switch issue. Does the reverse beeper work when your cart in reverse? If there is no beeper the the F/R switch is the most likely cause. Your F/R switch should be located in a housing under your seat. Take it out and reverse the wiring (most likely you will find a brown and a blue cable connected to it, those are the once you want to switch. Now forward will become reverse and if that moves your cart, you know for sure its the switch. If unsure take lots of pictures and post those with your question. that way we can see what you see. Adding images to an existing question
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 42
All Time: 3,391
3 Comments
Leonard Spinoso what model is it and gas/electric? what have you checked?
by oldturkey03
Gas or electric?
by rokin154
Checked wiring connections for my electric model
by Leonard Spinoso
