Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
Iphone doesn´t start anymore after display chage
Hello,
i got some small to huge problems. After changin the display my iphone doesn´t start anymore. I took me some weeks to remove the old display and assmble everything. So could this be the problem?
I tried to connect it via usb but nothing happens, also i tried to press and hold the home and on/off button for more than 30 secs.
Nothing happend so far.
Thanks for your help..
Cheers
Jan
1 Comment
Mine too dont know what to do now
by
Add a comment
Chosen Solution
This happened to me.
After replacing the screen, it continually displays the apple.
It appears that the ribbon cable labelled 3 was not correctly in place. Once this was corrected the iPhone runs fine.
Luc.
Add a comment
Sounds to me like one of the many ribbon connectors isn't seated properly. Best dismantle it again and check they are all pressed firmly into place.
1 Comment:
even i hv the same problem...i assembled it again but still its not turning on...
by
Add a comment
this happened to me
i coulld even call the phone and it would ring but i couldnt pick it up
turns out that the top right power button needed cleaning, was a bit dusty
Add a comment
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,292
