The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
191 Questions View all
Wii U Not starting; Blinking red light
i was recently wanting to play on my Wii u for the first time in a month or so. the light tuns on blue for a second with the fan coming on then blinking red light. it has been opened recently to be cleaned. any ideas
Score 1
1 Comment
J'ai ma Wii U qui affiche un voyant rouge tout en clignotant quand je tante de l'allumer, et le ventilateur à l'arrière de la console ne tourne pas. Que dois je faire?
I have my Wii U flashing a red light while flashing when I try to turn it on, and the fan on the back of the console is not spinning. What should I do?
by
Add a comment
Most Helpful Answer
I know this is an old post, but if you opened up the console and removed the disc drive, be sure to plug the flex cable in the same way it was removed. You can swap the cable around and it will fit, however you'll get the blinking red light when you try and turn it on.
Score 2
Add a comment
Make sure plugs are all plugged in. Did u have a game in it? Try to get it out and try again. Or maybe you left it on last time you played which can overheat it
Add a comment
https://www.bing.com/search?q=How%20to%2...
Add a comment
Add your answer
jake will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 48
All Time: 1,629
