Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Ipad will not charge, battery is good
So I have tested the battery with a multimeter and got a reading of 3.0V but the device will not turn on or charge. I have tried a hard reset and no luck. Is there a way I can determine if it is the logic board or the dock connector other than trial and error
Add a comment
1 Answer
Most Helpful Answer
Its got to be the charging port (dock connector) alone and not the battery or logic board.
Good luck bud
Score 2
1 Comment:
unless when open you see the dock connector is broken on the motherboard too/ then motherboard replacement may be necessary
by
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 45
