The map is not populating
My Magellan Maestro is not showing a map anymore. It is also not giving audio directions.
Hi,
What is the model number of your Magellan GPS?
Most Magellan units have a “reset” pinhole somewhere either on the side or the bottom edge of the device..
Try inserting a pin into the hole and check if you feel a pushbutton when you gently press down.
If you do, hold it operated for a few seconds and then release and then check if the device has been reset and is functioning correctly.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 55
