Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
3GS Not Wall Charging but Syncs and charges by PC
I recently bought a used iphone, I opened it to see if it had water damage and I didn't see signs of moisture damage. I had been using if for a couple of weeks and I started to notice that this showed up when I connected the 3GS to a wall charger "charging is not supported with this accessory"
I would just replug it in and it would start charging, this came up more frequently until it just doesn't show up (the message) and it just doesn't charge with the wall charger.
Weirder still is that I can charge it using my computer and sync, also charge using a mophie juice pack air and a powermat charger I have but if I have the phone connected to the juice pack while its charging it shows the "charging is not supported with this accessory" message. Please Help!
I think it may be the dock connecter that is acting up on me but I am not sure and I don't think its the battery as it still holds a charge :(
Score 1
Add a comment
1 Answer
Chosen Solution
How about trying another AC adapter. Be careful, some of the cheaper aftermarket chargers are known to destroy the charging circuit on the iPhone. I doubt that it is your dock connector or anything related to your phone. The dock connector uses the same pins for charging, no matter if it is from a AC adapter or from the USB port of your computer. Check on pinouts.ru and check the diagram ;-) Good Luck and let us know how it is going.
Score 3
2 Comments:
well I already did all that :/ I have a belkin wall charger, tested with my friends original charger, and some generic ones (these I don't use only till today) but none of them charge my 3GS and I know my belkin charger works because my friend can charge his iPad with it. Also before my Mophie Juice Pack could charge my phone and its battery at the same time but now it doesn't charge both at the same time only the battery for the Juice Pack.
by
that message is usually the dock going bad..try cleaning the docking part with a brush to remove any dirt etc. if that doesn't work then replace the dock connector.
by
Add a comment
Add your answer
abiuizquierdo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,030
