Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
callers can´t hear me, I can´t hear them after dropping my phone
I dropped my iphone 4 and now when it rings I cant hear the other person and they cant hear me. Ive tested the microphone and it recorded my voice fine, music plays fine through the speaker. It doesn´t change anything if I put the headphones in. I´ve taken the phone apart to look for loose connections and no problems found. Everything else works like normal as far as I can tell. Any ideas or more technical info would be much appreciated.
Add a comment
try to squeeze the left down corner (where the mic is) to see if its working.Then try to do this http://www.youtube.com/watch?v=EZmSVt8bM...
Its a problem of 4.3.3. u can find it on apple forums
Add a comment
Same problem here, I found that if you pressed around the connection to the dock ribbon cable inside the phone to the left of the battery, it worked. I tightened the screw under the water damage detector, and it worked intermittently, then i placed a piece of card over the area to add pressure when the case is on, and now it is fine.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 6,583
