The Sony Vaio Fit is a single touch screen laptop that has a unique tray flip allowing for tablet style usage. The laptop’s main attributes are an Intel i7 processor and integrated graphics card with the NVIDIA GeForce GT 735M and Intel Hd Graphics 4400.
6 Questions View all
How to fix battery not detected error on Windows 8.1?
Feb 13 I was using my laptop n put it on sleep at 7% because I was in a cafe and had forgotten to bring my charger. Got home and fell asleep, Feb 14 morning I turned laptop on without plugging it read battery 70%, as I was typing it died all of a sudden, then I remembered how the day before It was 7% not 70%, so I plugged it in, charge light won't turn on, so I press power, turned on but the charge light was blinking, then windows booted up, and it read no battery detected, unplugged and the laptop turns off.
Thought the battery died on me, so I ordered an original replacement battery online, Feb 16 it arrived, tried it on, same thing, no battery detected, tried shut down computer, unplug and power switch, turned on, still no battery detected,
used it for 2 hours or so and it turned off again, juice must've ran out, plugged in and it reacts the same as my original battery,
so I thought it's just a bad replacement battery so I went to the seller's place, tried 3 other batteries with the same result.
Still dunno how to fix, tried the reset bios setting, tried removing the small bios battery and discharge for method, tried driver uninstall method, tried a diff ssd method, same result. . .
Add a comment
1 Answer
I would like to help you with this issue. You may follow these methods.
Method 1: Run the power troubleshooter. Follow these steps:
a)    Press the ‘Windows + W’ key on the keyboard.
b)    Type troubleshooter in the search box and then press enter.
c)    Click system and security and run the power troubleshooter.
Method 2: Follow the steps from the article.
'''Battery: Frequently asked questions'''
Unexpected shutdown can potentially harm your computer , I suggest you to back up your computer before hand in case of any error may occur.
Add a comment
Add your answer
Anon545454 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,506
