Repair guides and support for motherboards and CPUs.
166 Questions View all
Question: How would you advise the customer and what would you suggest
You have just completed a fault diagnosis of their stand-alone non-networked AT system. The family uses this for internet access and general purpose applications including games. You have diagnosed a faulty CPU and PSU. The CPU is obsolete but you have a second-hand one in and old working motherboard. You can obtain a replacement AT PSU from your main supplier. Before you commence any repair work, you politely state your diagnosis, remedy and the cost of the repair to the customer. At this point Mrs. Malone asks you if the repair will be cost effective and whether a better option would be to upgrade the system with a new CPU and mother board able to accept modern add-ons like a digital camera. However at present they cannot afford a completely new system, but she is thinking of buying her husband a digital camera for his birthday.
To upgrade the old AT machine to an ATX system, the case, PSU, motherboard, CPU and RAM would have to be replaced. At the very best, the only salvageable items from the old system-unit are the Graphic Card, Sound Card, Hard Drive, Optical Drive and Floppy Drive. But when these are compared to today’s accepted specifications it is questionable whether these items are worth reusing. The existing Monitor, Keyboard, Mouse and Modem can be reused.
Question: How would you advise the customer and what would you suggest?
Score 1
Add a comment
Most Helpful Answer
Offer an option of getting a second hand HP desktop. These desktops are generally mid-grade with a 2nd to 4th gen i5 processor which is what most people need when they use it for general office use.
Since this will be used for some gaming it would need to be an ATX prebuilt with support for a PCI-E full size x16 graphics card. If the proposed desktop supports a GTX 1060 then it will be a good idea. I think these go for around $200-$400 which is a lot less than a new PC build.
Score 3
Add a comment
I would add up the cost to repair the computer (AT from the 80’s?) and then, based on what they want to do, suggest a more modern used computer. If the cost of repair costs more than the cost of replacement then go for the replacement. Used laptops are also fairly cheap.
Add a comment
Add your answer
analizacayabyab1981 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 116
