The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
Why wont my iPad turn on?
  1. My iPad wont start, I’ve tried different methods to restart it such as pluging it in till a computer with iTunes but it wont get recognised. When charging the iPad gets hot in the higher parts of the right side. I would be happy to get help with what parts could be damaged and what to do.
Score 2
2 Comments:
Connect your iPad to the computer and enter DFU mode by press/hold home button and lock button for 5-8 seconds, then release lock button while keep holding home button, after a few seconds you should get a prompt in iTunes - try restore iPad in DFU mode and see it can solve the issue.
by
I've tried that. But thanks anyway!
by
Add a comment
1 Answer
Well it could be a number of things first thing that comes to mind is that when you say it heats up is it when its on? Also do you see any icon or anything on the screen at start? If you don’t see anything on your ipad air it could most likely be a backlight which has gone out and may need to be replaced and since it heats up it may need a new battery since it shows symptoms of failing.
1 Comment:
Thanks for the answer! No I can't see anything other than that it heats up att one spot while charging.
by
Add a comment
Add your answer
Jonas Björs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 119
