Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
289 Questions View all
Wii will not display properly
Wii will not display in 480p, it has worked properly for years, and all of a sudden the video would turn off and come back on, everything else seems to be working. I have powered it off, un plugged it, every time I turn it on, the visible screen turns on and off.
Score 1
4 Comments:
have you tried replacing the video cables?
by
If it had been working before it gives a hint that something has come loose internally. This often happens on retro computer and game consoles, in which the solder on the video jacks inside has become undone from the board. You can verify this by dissasembling the Wii and checking the jacks. I'll link a dissasebly guide for you below. Hope this helps!
The guide below shows the dissasembly to the motherboard. However you'll find the jacks on the opposite end of the board.
Wii Dissasembly Motherboard:
Nintendo Wii Motherboard Replacement
by
Ok thanks , I'll check that out. If the solder is broken is that issue possible to fix ( just resolder it)?
by
It came on last night and worked for a while. The screen flickered a few times and went black but then came back on. Even when it was on, the color was off balance , almost like too much red. There were also visible shadow lines across the screen.
by
Add a comment
1 Answer
It's possible that one of the AV Cords (the yellow one) might be damaged. You could buy a new one to see if that works and if it doesn't you can always return it.
Add a comment
Add your answer
RODNEY SQUIRES will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,921
